Old 04-03-2013, 08:46 PM   #1
JointTech
JointTech's Avatar
Hazards
Finally got all my lights working and got a new flasher for the hazards. Its an LED flasher and has the reverse polarity adapter in case its needed. All my turn signals etc work but the hazard does nothing.
On a 72 non tilt column is the hazard button always on the right side of the colomn and red? just making sure its stock.
The fuse is good. I was looking at the wiring diagram to try to trace it down but dont see what wire color I should be looking for there.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 04-08-2013, 02:35 AM   #2
JointTech
JointTech's Avatar
Re: Hazards
SO I have one LED flasher from LMC. I got another to use on the hazards from Classic Parts.
Both of them came with flipfloppers to reverse the polarity if needed.
BUuutt.... The Classic parts one has a wire coming out the top as well with a blade connector on the end. I thought it must be for some other application.
Well today I figured wth and went ahead and grounded that connector. voila, hazards work!!
Wonder why the classic parts one required me to drilla hole for a ground screw??
weird, but its working now.
72 C20 Long Bed
