removing axles
first time removing axles from my 66 c10,getting drilled from 6 lug to 5?any suggestions?
Re: removing axles
Remove wheels, remove drums, pop rear diff cover, drain oil, remove cross shaft pin bolt, remove cross shaft, tap axles inward just enough to allow c-clips to drop out, then pull axles out.
Re: removing axles
awsome thanks.im still debating wether i should get them drilled out.or just doing the conversion swap.
Re: removing axles
While you have them out you might as well change the seals and maybe the bearings.
66 shorty ![]() |
Re: removing axles
Most importantly, DO NOT rotate the differential gears(turn the driveshaft) once the cross pin is removed. If you do, you will have to realign the spider gears. It's not disastrous, but time consuming and frustrating.
Re: removing axles
thax for the great tips fellas
Re: removing axles
I had the original axles on my 65 Suburban re-drilled to a 5 lug patter by Moser in the mid 90's. Simple enough process, just take your time.
Re: removing axles
should seals and bearings be changed if they look so..so
Re: removing axles
finally got my axels back from cooks machine works in e.l.a.drilled to 5on5,cant wait to slap them on.yaaay
Re: removing axles
I would change the seals just because you have the axles out and they are cheap.
66 shorty ![]() |
#11 | |
Re: removing axles
Ounce of prevention and all that...
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
