Old 04-03-2013, 10:50 PM   #1
Procurement_man
Procurement_man's Avatar
convert high hump to low hump
I want to make it low. Does anyone make a patch panel, or do I have to fab one up on my own? Working on a 72
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel
Procurement_man is offline   Reply With Quote
Old 04-04-2013, 12:47 AM   #2
Racer2172
Re: convert high hump to low hump
Sent you a pm
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 04-04-2013, 06:59 AM   #3
jjzepplin
jjzepplin's Avatar
I traded a fellow on here a high hump for a cutout piece from a donor cab (low hump) and drilled holes in it and bolted it in. I have a 3" body lift (yes my frame shows) So this put my twin sticks for the transfer case back where they should be.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-04-2013, 01:43 PM   #4
67c10rustbuket
67c10rustbuket's Avatar
I am pretty sure I have the piece that I removed to make mine a high hump. I will check tonight. If It is still here you can have it. Just come get it.
Pic shows where I cut it, would have to be welded in. If you want to bolt a piece in you might try to find a larger section of a cab floor and cut it out the same size as the HH.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 04-27-2013, 12:21 AM   #5
67c10rustbuket
Pics for the P_man. This is the piece I cut out to install a high hump. The front section has separated and would need to be welded back together. It's yours if you want it. I can PM you my phone number to make arrangements.
Dan <---(my name)
