Old 04-03-2013, 10:53 PM   #1
rsmarr1982
rsmarr1982's Avatar
350 4 bolt main block
i have a 350 4 bolt main block 2 piece rear main std. bore. with main caps asking $200 SHIPPED (to your closest fastenal company retail store in the cont. 48). fastenal has over 2000 stores in the us if your interested go to fastenal.com and locate your store of choice.
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 04-03-2013, 10:58 PM   #2
HotRod C/10
HotRod C/10's Avatar
Re: 350 4 bolt main block
what is the casting #?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 04-03-2013, 11:02 PM   #3
rsmarr1982
rsmarr1982's Avatar
i will check it out first thing in the morning. you want the number in the rear where bell housing bolts up or number above the water pump mounting spot?
Old 04-03-2013, 11:03 PM   #4
HotRod C/10
bellhousing area please
LS SWAPPED
-1976 SILVERADO
Old 04-04-2013, 01:05 AM   #5
rsmarr1982
rsmarr1982's Avatar
Number is 397000
Old 04-04-2013, 03:31 AM   #6
Oddfire
Oddfire's Avatar
I believe you mean 3970010.
Oddfire is offline   Reply With Quote
Old 04-04-2013, 09:21 AM   #7
J kippin
J kippin's Avatar
could you tell me what year the block is and the condition of the bores and mains...I will take it if it is a 71 block with good bores and mains
J kippin is offline   Reply With Quote
Old 04-04-2013, 10:45 AM   #8
rsmarr1982
rsmarr1982's Avatar
correct i unburied it today there is a "1" in there casting id says 69-79. there is light rust on bores its been sitting since mid 90's . i would have any engine bored before putting any money into it anyway , boring is not expensive compared to tryin to save a couple hundred and have maybe have one cylinder burn a lil oil.
Old 04-04-2013, 11:46 AM   #9
J kippin
J kippin's Avatar
Boring is not a problem.. I just want to be sure it does not need to have liners installed or has had the mains spin and need to be align bored. What are the front pad numbers?
Old 04-04-2013, 02:57 PM   #10
rsmarr1982
rsmarr1982's Avatar
The front Id cannot be made out sorry
Old 04-04-2013, 03:02 PM   #11
J kippin
J kippin's Avatar
what is the date code on the block?
Old 04-04-2013, 03:06 PM   #12
rsmarr1982
rsmarr1982's Avatar
Only codes are on back by bellhousing and suffix code on front which cannot be made out
Old 04-04-2013, 04:25 PM   #13
J kippin
J kippin's Avatar
it should have a 3 or 4 digit code on the back of the block near the cast number or the right side of the bell housing area. It will be a letter to designate the month next will be the day and the last year cast. It may also have a circle with a arrow in the middle showing the time of day and shift it was cast.
I wont to be sure it is a 71 or earlier block. most blocks are cast a few months before production but a few earlier ones have been used.
The stamped numbers don't mean a whole lot to me.. other than it may show as a truck block. If this was a Corvette I would want a numbers stamped block. Most of the time the numbers are milled during decking, or it may be a replacement. I have found the numbers at the 12 o clock position above the timing cover.
Old 04-04-2013, 04:53 PM   #14
CC69Rat
CC69Rat's Avatar
J kippin, .. I might be uncovering some stuff here that you don't want me too If so, man I apologize.
But, what you're probably looking for is an 010/020 stamp under the timing sproket on the cam gear and / or a stamp on the main caps with the numbers beginning 24xxx.
rsmarr1982, it would be well worth your time to check these two places.. hint.hint
Just trying to help.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-04-2013, 04:56 PM   #15
rsmarr1982
rsmarr1982's Avatar
It is an 010/020. I know that.
Old 04-04-2013, 04:59 PM   #16
rsmarr1982
rsmarr1982's Avatar
Is a pre 71 block that much different ? The only number possible to see when its in a truck is the casting id
Old 04-04-2013, 05:17 PM   #17
CC69Rat
CC69Rat's Avatar
post 71 they were a little 'less' nickle/tin content. IF this is a real High Nickle core, somebody grab it. These are getting harder and harder to find. Dirt Trackers use them a lot.
Chad
Old 04-04-2013, 05:54 PM   #18
J kippin
J kippin's Avatar
okay like I said I will take it just as long as the other casting numbers check out.
Old 04-04-2013, 06:36 PM   #19
rsmarr1982
rsmarr1982's Avatar
It is a 75 block
Old 04-04-2013, 06:43 PM   #20
J kippin
J kippin's Avatar
Sorry not quite what I am looking for I already have a few of those Iam looking for one a little older.
Old 04-04-2013, 11:29 PM   #21
rsmarr1982
rsmarr1982's Avatar
pics
Old 04-05-2013, 07:15 PM   #22
rsmarr1982
rsmarr1982's Avatar
Anyone? Id hate to just scrap it
Old 04-07-2013, 09:35 AM   #23
rsmarr1982
rsmarr1982's Avatar
$150 shipped to your nearest fastenal store. after today it goes to the scraper.
Old 04-07-2013, 10:20 AM   #24
mrdana60
Wouldn't junk it. Someone needs it. Lol. Maybe someone gets it.
mrdana60 is offline   Reply With Quote
Old 04-07-2013, 09:13 PM   #25
rsmarr1982
rsmarr1982's Avatar
im in process of cleaning out my parents garage and ive have stuff like this in there since i was a teenage at home . i just dont have room for it .
