![]() Join Date: Jan 2013
Fluid spraying out of #8, #6 cylinders
I am suspecting I have a head gasket problem, as my truck is losing coolant internally, and oil that leaked out (due to loose oil pan bolts that I just noticed, I think) over a couple days had noticeable coolant in it. I did a coolant pressure test, which was good. Then I tried to do a compression test, the first one I've done on this truck, but 8 and 6 were spraying fluid, I think fuel but it was really hard to tell. Could be coolant, but it was only those two cylinders.
Could this be due to stuck valves? I know the seals/guides need replacing as blue smoke comes out at start up, but could this cause fuel spraying all over the place? Incidentally, I think the fuel/fluid messed up the gauge. I did #2 and #4, and both those came up with about 60psi, before and after squirting oil into the cylinder. After I did #6, the gauge stopped working. Secondly, would worn guides/seals cause such a terrible reading? Or the head gasket? Im going to drain the oil as soon as I can to check it, but I have never seen white smoke. I did find the intake manifold bolts were a bit loose, but I dont think enough to cause these problems. Ironically, I just finished putting the MadElectric New System in (best upgrade yet!), and my truck is running smoother and pulls stronger than ever. I was just getting ready to finally start work on sound when I found the leak
Josh 72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs... |
Re: Fluid spraying out of #8, #6 cylinders
Sounds like you have a head gasket problem (or worse). I'd at least pull the heads and see whats going on, or just pull the engine and go through it completely.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
Quit if it's not FUN!!!
That's the way these old trucks do you. I spend enough time just keeping my DD roadworthy. I have to make time for upgrades. :: Sounds like at least a head gasket problem. Pull the heads, have 'em checked for flatness, cut if necessary. Make sure the block surface is "flat". The steam hole between #6 & #8 on SBC have a weak spot. Best of Luck. Let us know what you find
Could the fuel spraying out the cylinders be due to a valve problem? A cracked head gasket wouldnt cause anything to spray out the cylinder would it?
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Could be coolant and thats what I think it is because 6 and 8 are right next to each other
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Yeah, I guess at this point pulling the heads is the best choice. How hard is it to do a full valve job? Or would it be better/more cost effective to just replace the heads instead? I'm assuming machining heads isn't cheap
