Old 04-04-2013, 02:39 AM   #1
Mltx2
Wiring question
I'm trying to put on traditional tail lights. They light up iwth the lights on, but when the brake pedal is pressed down, the lights go out. Any suggestions? The old lights still work fine and it's a 12v system
Mltx2 is offline   Reply With Quote
Old 04-04-2013, 07:11 AM   #2
lazypineapple
lazypineapple's Avatar
Re: Wiring question
Ck the grounds
lazypineapple is offline   Reply With Quote
Old 04-04-2013, 01:37 PM   #3
_Ogre
_Ogre's Avatar
Re: Wiring question
if your front marker lights go out too then you have the wires crossed
shop air compressor timer
Old 04-04-2013, 06:03 PM   #4
mr48chev
mr48chev's Avatar
Re: Wiring question
Originally Posted by lazypineapple View Post
Ck the grounds
Yep your lights are grounding through the other side of the bulb as it stands.
You either don't have the bulbs in the sockets right or you just don't have the sockets grounded to the truck.
My ongoing truck projects:
Old 04-04-2013, 06:41 PM   #5
mr48chev
mr48chev's Avatar
Re: Wiring question
Thinking on that, are you using stock tail lights as in the original GM ones or ?
How do you have them wired, stop and Tail only or for Stop/turn and tail ?
When you mounted the lights did you use any insulators like rubber or plastic between the housing and the bed ? Paint alone would be a good enough insulator to keep the lights from grounding properly. If you don't have a ground wire from the socket I'd run a ground wire from the outside of the socket to the frame of the truck.
Old 04-04-2013, 06:50 PM   #6
vintageozarks
vintageozarks's Avatar
Re: Wiring question
I agree you are missing a ground might be the body ground its mounted in rubber
vintageozarks is offline   Reply With Quote
Old 04-04-2013, 07:51 PM   #7
Mltx2
Re: Wiring question
the tail lights I purchased from the classic chevy dealer had just 2 wires (white & black) and a 12v two filament bulb. When I purchased the truck it had some generic aftermarket taillights that ran three wires, one wire ran the reverse light, the other two wires went to the 12v two filament bulb. I still have one of the after market lights attached. I cut the wire to the reverse light and the aftermarket light it still works correctly with the running lights & brake light. The after market light i removed was working correctly.
I'm not sure of the wiring scheme. I'm the 4th owner, the previous two owners have put in a V8 engine, front end clip and had it repainted (which is when I presume it was re-wired.
Old 04-04-2013, 07:52 PM   #8
Mltx2
Re: Wiring question
Old 04-04-2013, 11:03 PM   #9
Mltx2
Re: Wiring question
I figured it out. It was a grounding problem. The two wires are hot (one for brakes, the other for running lights). The light housing itself has two threaded studs that when bolted to the mount (attached to the truck body) serve as the ground. It was a grounding problem, I was just looking at the wrong solution.
Thanks for the help and advice.
