Old 04-04-2013, 09:30 AM   #1
ccsrcr
Converting Truck or Suburban door to a Blazer or Jimmy
I saw a post where a guy converted a truck door over to a blazer, but would that alse be possible with the suburban door ? The main reason for asking is the suburban door is cheaper on LMC, and if im already going to cut it up, I might as well start with the cheaper one.
ccsrcr is offline   Reply With Quote
Old 04-04-2013, 04:48 PM   #2
orange72blazer
orange72blazer's Avatar
Re: Converting Truck or Suburban door to a Blazer or Jimmy
I asked this question years ago & it will work, here is a link to the thread
http://67-72chevytrucks.com/vboard/s...d.php?t=328635
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is offline   Reply With Quote
Old 04-04-2013, 05:50 PM   #3
Jdubs71
Jdubs71's Avatar
Here is a link to a thread another member did converting the truck door to a blazer door.
http://67-72chevytrucks.com/vboard/s...d.php?t=273729
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 04-05-2013, 03:05 PM   #4
ccsrcr
Thanks, Suburban doors are $140 than blazer cheaper on LMC, so trying to decide if that is the route to go. At least one of my re-inforcement plates would require some repair, but that would be a $280 savings on just the doors alone.
Old 04-05-2013, 03:22 PM   #5
SamMargritz00
SamMargritz00's Avatar
mine was done that way. itll work
Blazer Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=483399
SamMargritz00 is offline   Reply With Quote
Old 04-05-2013, 07:52 PM   #6
Jdubs71
Jdubs71's Avatar
I wouldn't recommend buying repop doors. The metal is lighter and they don't fit nearly as good as original. I found a set of clean original truck doors for $100 including all the glass and hinges.
My build thread
Old 04-06-2013, 09:17 AM   #7
ccsrcr
Wish I could find some nice clean doors for that. Mine could probably be repaired, but it would be quite a bit of work.
Nice build. Im also swapping in some newer axles under mine, but they are 3/4 ton. I bought an entire 89 suburban to use for the swap, and will probably run the TBI for now, but do plan to go with a 6.0 and 4l80e in the future.
Old 04-06-2013, 09:50 AM   #8
Jdubs71
Jdubs71's Avatar
Thanks. Its been slow going for me. My baby girl is now 5 months old so thats about how long its been since I've done anything. I have still been buying up parts so when I'm ready to start back up i'll have plenty to do. Good luck with your build. Lots of good info and people on here. I wouldn't have attempted this project without all the knowledge and expert advise on here.
My build thread
Old 04-06-2013, 10:25 AM   #9
ccsrcr
Yes, for sure. This site is a great resource, and everyone is super frienddly. It will be a huge help.
Congrats on the little girl.
