Hinged steel in-bed fuel filler?
I am using an in-bed fuel filler due to my paint being several years away from being re-done. I planned on going the boat deck filler route as I have seen, but my Boyd's Welding tank filler neck would need to be cut and welded with 2" pipe to accept the boat neck.
Has anyone ever carefully cut the bed floor and actually used it as the hinged piece? I think it might actually look cleaner than the boat filler. Of course I wouldnt be able to load it heavilly in that spot, but my truck's work duties have pretty much been retired anyway. Some spot welded 1/8" flat bar should give it enough support. This is a rough napkin sketch of the concept ![]() |
the boat guy
Re: Hinged steel in-bed fuel filler?
That would definetly keep less junk from getting in your gas tank.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
![]() Join Date: May 2008
I grafted a gas filler door off a junk yard car that had a cable release and would open when pulled from the drivers seat. I shortened the cable and routed it to my license plate. I got this just like I like it and then cut and welded my gas tank cap and flange to fit right under the filler door.
[IMG]
Mine is chopped, has a clutch, and a big block. |
