Old 04-04-2013, 03:26 PM   #1
FOSTER21
67-72 frames
I'm looking for a swb frame are they all the same or is there any difference?
FOSTER21 is offline   Reply With Quote
Old 04-04-2013, 04:23 PM   #2
leftybass209
leftybass209's Avatar
Re: 67-72 frames
To the best of my knowledge they are the same overall. That being said, there are coil spring and leaf spring rear ends, 6 lug or 5 lug, and I believe some axle widths in the rear are slightly different. I'm sure others can point out more specifics.
leftybass209 is offline   Reply With Quote
Old 04-04-2013, 09:42 PM   #3
ecgate
ecgate's Avatar
Re: 67-72 frames
The 67 frames don't have a dimple for the power steering. You need a bfh to manufacture one and then you can bolt the power steering gear on the frame.
ecgate is offline   Reply With Quote
Old 04-04-2013, 11:02 PM   #4
oklalawnboy
oklalawnboy's Avatar
Re: 67-72 frames
Somebody correct me if I'm wrong but I think the 62-66 frames are the same as 67-72.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 04-04-2013, 11:26 PM   #5
Likewhoaman
Re: 67-72 frames
I heard that 64-72 frames are all the same but you might have to just relocate the cab mounts. Anyone correct me if im wrong. Btw i might know a bud of mine that has one for sale. Its located in Louisiana
Likewhoaman is offline   Reply With Quote
Old 04-05-2013, 09:31 AM   #6
c10srule
c10srule's Avatar
Re: 67-72 frames
the 62-66 frames have a different radiator crossmember, the front is different for the bumper and the rear cab mounts and radiator support mounts have to be moved, we put a 63 on a 70 frame, as far as the front for the bumper we cut the ends off the 63 frame and welded them on the 70 frame
c10srule is offline   Reply With Quote
Old 04-05-2013, 10:02 AM   #7
67c10rustbuket
67c10rustbuket's Avatar
Re: 67-72 frames
The 67 power steering recess aka "dimple" is the most notable as others have said.
Another oddity on 67 frames is the flanges on either side of the engine are wider than later trucks. I have read this was because the BBC was offerend in 1968 and up. The flanges were then narrowed to make room for the bbc exhaust. The flanges measure 2.5" on a 1967 frame and 1.8" on 1968-72 frames. It may seem like nothing but will become a pita if you run headers even on an sbc and a nightmare if you want to run headers on a bbc. (the rails will need to be trimmed to clear your headers)
You also have to consider the core support mounts, the holes come in two different sizes. One version for 67-8 and then 69-72. This is pretty easy to overcome.
Some later frames have a section of the lower flange rolled down under the cab. Not sure what this was for, maybe ease of installing the trans x member??
To identify a frame year by the partial vin locate the stampings either under the cab on the top rail and/or on top of the frame between the upper control arm and steering gear box. The first number is the year. The partial vin will be like this:
7A123456 7=1967 A= Atlanta assembly 123456= assembly sequence
8A123456 8=1968
9A123456 9=1969
etc
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
