Old 04-04-2013, 07:09 PM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
'69 Manual Master Cylinder (Disc/Drum) Bore Size
What would the correct bore size be for a 1969 pickup with a manual disc/drum setup?
Also, what master cylinder would you recommend for this setup? The individual is looking to cleanup under the good and would like a proportioning valve mounted up under the master cylinder.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-04-2013, 07:40 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: '69 Manual Master Cylinder (Disc/Drum) Bore Size
I believe it's 1" bore iirc.
-Nate
Old 04-04-2013, 09:41 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
1" is what I would use.
Aluminum only!
Keith
Convert to disc brakes.
Old 04-04-2013, 11:16 PM   #4
ulakovic22
Based on what I have researched, these trucks only came with 1 1/8 bore for manual and power disk/drum. Most people, myself included use a Corvette master, which is a 1" bore. POL has an aluminum Corvette MC and the prop valve can be mounted under the MC or to the side like factory.
ulakovic22 is offline   Reply With Quote
Old 04-05-2013, 05:24 AM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for the info.
He just located the CPP version with the built in proportioning valve. So we'll see where we end up.
-Nate
