Old 04-04-2013, 07:32 PM   #1
MyNewFoundGlory
MyNewFoundGlory's Avatar
230 or 250?
I realize all the components are mostly, if not all, interchangeable between the 230 and 250. But this is just for my knowledge and ego. Can someone help me differentiate between the two. I've check many threads and found the engine was made in Canada and the month and year but im lost on the "ST" meaning. Please help!
Attach: the stamped #'s
Steve
1964 C10 I6 StepSide
2012 Cruze RS 1.4T
MyNewFoundGlory is offline   Reply With Quote
Old 04-04-2013, 07:34 PM   #2
MyNewFoundGlory
Re: 230 or 250?
Casting number:
Steve
2012 Cruze RS 1.4T
Old 04-05-2013, 09:26 AM   #3
Lugnutz65
Lugnutz65's Avatar
Re: 230 or 250?
I tried to help. Failed to find anything except what you said. Time will solve the matter. (Probably)
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-05-2013, 09:40 AM   #4
MyNewFoundGlory
Re: 230 or 250?
I appreciate the attempt. Thank you lugnutz
Steve
2012 Cruze RS 1.4T
Old 04-05-2013, 10:05 AM   #5
60-66
60-66's Avatar
Re: 230 or 250?
The ST suffix shows up as it was in a "P10" VAN? 230 Cu In for 1966 and 1967 . ST code was not used in 1965 or 1968.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 04-05-2013, 10:17 AM   #6
MyNewFoundGlory
Re: 230 or 250?
So you're saying it is a 230? Yea I was told the motor was replaced once before in the 70's but I figured it was a direct replacement, not a different vehicle type. Thanks 60-66
Steve
2012 Cruze RS 1.4T
Old 04-05-2013, 10:21 AM   #7
1963c-10
1963c-10's Avatar
Re: 230 or 250?
All I could find was 64-76 230/250 chevy/olds
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-05-2013, 07:36 PM   #8
Lugnutz65
Lugnutz65's Avatar
Re: 230 or 250?
This is ironic, really. I tried to help you and now I'm in a similar fix. I just bought a 66 parts truck. Engine looks original, but nope. I have the little book from the dealer with the engine number stamped onto the protect-o-plate (a little metal card) that came with the truck. The card says the engine serial # is F0124TF.
You can see my photo of the engine serial# stamp says F1112TP1 or maybe F1112TP7. I'm stumped. I can't figure what it's from. Could be from a Nova or maybe a later model truck. We shall see. Mystery.
So it's not the original engine. I had suspicions because the crank pulley is a double groove and the truck doesn't have any PS setup.
The good news is that this motor might actually turn out to be OK for me to use. That'd be a bonus for me since my original 230 has bad compression numbers.
EDIT: OK I just figured out that the last 3 are all letters - F1112TPT. According to the LMC catalog, my engine is a 250ci from a 71 or 72 truck. That's cool. I can live with that.
Jay
