Old 04-04-2013, 09:13 PM   #1
BLUE49
Power Steering question
I have a 49 3100 with a 250 c.i. in line. I just finished installing power steering and got the engine running again. When I started the engine the steering wheel violently went to the right steering lock and made a lot of noise. I think my problem is that I have the pressure and return lines reversed. Its kind of strange that they would make both ports on the steering box the same size, or am I doing something else wrong. Both pump and box are new rebuilts from a '76 C10.
I just thought I would check with you guys before I tackle this in the am.
BLUE49 is offline   Reply With Quote
Old 04-04-2013, 11:22 PM   #2
parkwood
parkwood's Avatar
Re: Power Steering question
Your hoses are crossed.. did that once on my '57 nomad and almost broke my arm.. not sure what box you are running but i know on racks it's the small port that's the high press...
parkwood is offline   Reply With Quote
Old 04-05-2013, 11:27 AM   #3
BLUE49
Thanks for confirming my solution. Isn't the internet great - I post something that covers the whole nation and I get an answer from a few miles away!!
Old 04-05-2013, 11:42 AM   #4
mr48chev
mr48chev's Avatar
If you have a 76 GM pickup box on it you should not be able to cross the lines as the fittings on the box are different sizes. Unless it has the oring style fittings and I am not sure if the nuts on those have different size threads like the boxes that have flaired fittings do.
When I was working on power steering boxes and pumps every day I got in the habit of having the front wheels of the rig off the floor when I first started the rig up and turned the wheel back and forth to work the air out. It just seemed easier on the whole system to do it that way.
My ongoing truck projects:
Old 04-05-2013, 12:31 PM   #5
youngrodder
youngrodder's Avatar
Another thing to point out is be sure the bleed the air from the system prior to starting it back up. Air in the system can cause for some strange steering response.
Marc
oooops I didn't read that Mr 48 already covered off on this subject....
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 04-05-2013, 10:23 PM   #6
parkwood
parkwood's Avatar
Yes blue, we're everywhere....
Old 04-06-2013, 03:30 PM   #7
_Ogre
_Ogre's Avatar
scary...
shop air compressor timer
Old 04-06-2013, 07:59 PM   #8
BLUE49
Thanks for all the help, guys. I did have the lines reversed. Oddly, on this box the large fitting is the pressure line. Go figure. Just for info purposes, I used the Earls AN connections and hose. It gives a much more flexible line and looks better too.
Old 04-06-2013, 11:29 PM   #9
mknittle
mknittle's Avatar
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-06-2013, 11:33 PM   #10
mknittle
mknittle's Avatar
Blue you are surrounded
Mark
My GMC build.
