headers for a sbc in tf truck
ive got a 57 truck with stock steering box and suspension
it has the tubular engine cross member with a sbc only accessory is a alternator has anyone successfully installed off the shelf headers that fit decent block huggers,shorties,long tubes anything? if so brand and part number would be awesome as well as pics lol thanks in advance any advice is apreciated |
Re: headers for a sbc in tf truck
Block huggers were the only thing I could get to fit.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
![]() Join Date: May 2011
Omg, I went through a difficult time with headers. I asked this question long ago and just had to go by the seat of my pants or skirt, lol. I started with some block huggers, then changed to some Chinese long tube headers that wound up being deformed and fought to get my money back from the vendor!, then bought some Hedman headers that I really like, didn't hang down as far as I would like, but they "feel" solid, not tinny like the Chinese stuff. You can see them on my build thread. I have the stock frame with the Saginaw steering box conversion and a th350 tranny,sbc engine, with crossmember removed
![]() dne' ![]()
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
Before I rebuilt my truck I had a set of hedman headers i got through summit.I had to dimmple one of the tubes to clear original steering box.The truck is a 57 original v8 but i used the tube type motot mount.sorry I dont have any pictures of that on computer.
1957 3100 ![]() 1950 5 window |
#5 | |
I just posted the same question! Would be good to get some specific feedback. Thanks alot
![]() ![]() Join Date: Nov 2008
I'd love to answer questions but I can't cause I didn't install my headers, they were on the truck when I bought it.
Not sure you can see it in this photo but whoever installed them did have to put a small dent in one tube to make them fit. ![]() I WANT to remove them to have them coated - but honestly? They may be paper thin and I'm afraid the bolts would snap off in the heads, then I'd be SCREWED. I've read all the things to use: heat cherry red, use 50/50 ATF & acetone, the candle trick, tighten before loosing, etc. ALL of them have their proponents and failure stories. Last edited by Dan in Pasadena; 04-12-2013 at 09:47 PM. |
The pair I used were long tube headers.I went and looked in my file and found the headman part number from summit hed-69260.I had to dimple tube on drivers side.Also had to notch out bottom of bellhousing cross member to clearance exhaust.
