I have a 79 c10 found water is getting into my cab through the seam under the cowl vent and I've sprayed two cans of undercoating on it to seal the seam and it works fine for a few days but the coating crack's and water finds its way back the cab anybody have this problem and what did you do to fix it
![]() Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
TEXAS BOYZ WITH CHEVY TOYZ ![]() |
78K & 79C Jimmys
Re: rain getting in the cab any ideas how to fix it?
caulking or body sealer
how this side area?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
When I thought my kick panel vent was leaking water into the cab, it turned out to be the corner of the windshield. The bottom corners of the window frame are a common rot spot.
Proud UA member since 2009 My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660 Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA |
Use a tube of autobody seam sealer it that is the leak spot.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
