Old 04-04-2013, 10:13 PM   #1
ecgate
ecgate's Avatar
Fuel line size??
I've been getting mixed reviews about this. But anyway I have a 402bbc with a mechanical pump a aluminum fuel tank in the rear of my 67. What size fuel line should I run from the tank to the pump and what size line from the pump to the carb? Do I need a filter between the tank and pump and a filter between the pump and carb?
ecgate is offline   Reply With Quote
Old 04-04-2013, 10:49 PM   #2
Wizzy72
Re: Fuel line size??
I would say 3/8 ID line would be sufficient and use a filter between your pump and the carb.
Wizzy72 is offline   Reply With Quote
Old 04-04-2013, 10:58 PM   #3
buckskins4ever
buckskins4ever's Avatar
X2......unless you are using a dual feed double pumper on that BBC
buckskins4ever is offline   Reply With Quote
Old 04-05-2013, 08:20 PM   #4
ecgate
ecgate's Avatar
What do you recommend if Im running a holly double pumper carb.
Old 04-05-2013, 08:25 PM   #5
69GWC
Unless that thing is Built up alot 3/8s would be fine IMO.
69GWC is offline   Reply With Quote
