Old 04-04-2013, 10:59 PM   #1
anglebinder
temp gauge stubborn
I have a 67 with a 350. Temp gauge is buried over on hot. Have new wiring harness, grounded the cluster, grounded temp gauge to cluster at bottom post (6:00 on the 4 posts). Gauge did work before new wiring harness. Printed circuit board appears to be ok.
Any ideas appreciated.
anglebinder is offline   Reply With Quote
Old 04-04-2013, 11:10 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: temp gauge stubborn
Here is how the gauge is wired and it appears that you have it correctly wired.
The symptom you have is caused by the temp sensor green wire being grounded at some point between the sensor and the gauge. If the sensor is grounded internally it will also read hot.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-04-2013, 11:22 PM   #3
anglebinder
Oh, Uh the 90 ohm ceramic resitor seems to be missing. Maybe that could have something to do with it.
Old 04-05-2013, 06:50 AM   #4
Daddy'O
Daddy'O's Avatar
Yes Sir - an open resistor (or missing in your case) will cause the gauge to read hot. Don't ask me how I know - lol.
Cheers - Wayne
Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966
'55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157
1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy"
1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55
Nothing sucks more than that moment during an argument when you realize you're wrong.
Daddy'O is offline   Reply With Quote
Old 04-05-2013, 09:49 AM   #5
anglebinder
Thanks guys,
and the pic was great!
