Drive Shaft Replacement?
Can anyone point me towards instructions on how to replace a driveshaft in a 1964 Chevy C10 Longbed? It has a 350ci V8 + TH350 Auto Trans. I also have the 1963 C10 shop manual but I'm not seeing anything in there regarding driveshaft replacement.
More background: Currently whenever I try and put the truck in gear I am getting a very loud grinding noise and my neighbor was visually able to tell me that something was wrong with the driveshaft. Now I just need to get it out and have one fabricated (or have this one rebuilt) Thanks in advance. |
Re: Drive Shaft Replacement?
I should also mention that its a 2pc driveshaft.
Thank you Woogeroo!
I managed to get the drive shaft off successfully this weekend.
As far as I can tell the center carrier bearing it toast and the slip spline (not sure if that is the right term) appears to be sheared off the 1st part of the drive shaft where it meets the 2nd part. I took it to a repair shop and they want ~$600 to repair it. Anyone know if this is a good deal? Would it be better to just get a new one? |
Is this a drive line repair shop...? seems to be way over priced...!
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
It is a drive line repair shop.
![]() Join Date: Oct 2006
yea thats way up there. Call South Bay Driveline in San Jose
(408) 995-6000 See what they can do for you
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
I dont think your drive shaft should be moving if your setting still or was the truck moving when you hear the grinding noise
Thanks! I will give them a call in the morning.
thebobbykey I believe the grinding noise was from metal on metal rubbing vibration where shaft was severed.
#12 | |
