Old 04-05-2013, 09:19 AM   #1
rs74
rs74's Avatar
How do I change the glovebox lock and latch.
I want to take it off so I can prep it for paint. I noticed there is a little hole in the center of the little latch handle. Do I stick a pin in there and it releases it from the backside? I guess there is no lock so don't know why I put that in the title.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-05-2013, 10:09 AM   #2
Desert1957
Desert1957's Avatar
Re: How do I change the glovebox lock and latch.
For non-key lock latches:
Latch the latch with the glove box door open.
Use a straightened paperclip in the top hole (the hole pointing at the passenger door with the glove box open) to push and release each of the tumblers one by one as you slowly remove the cylinder assembly.
Unscrew the round piece from the outer side of the glove box door.
Desert
Desert1957 is offline   Reply With Quote
