Old 04-05-2013, 10:11 AM   #1
rs74
rs74's Avatar
Trying to decide on engine paint color.
I am getting ready to put my 355 together and need to decide on a color. Since the truck is going to be indigo blue and a silverish color I don't want to do the traditional orange. I have a pic of a truck painted the same color except it has the LS engine in it. I have been thinking about painting the block to look like it (aluminum) but not sure it would come out right. Then top it off with the black valve covers that have Chevrolet scripted in red. Anyone know of any good engine paint that would be close to the aluminum. I will also have polished ceramic coated headers to go with. Here is a pic of LS engine.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-05-2013, 10:31 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Trying to decide on engine paint color.
I would paint everything under the hood blue, and paint the motor silver to make it pop.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-05-2013, 10:35 AM   #3
rs74
rs74's Avatar
What is the best brand paint to buy for engines. All I know of is VHT.
Roy
1987 R10 shortie
Old 04-05-2013, 11:09 AM   #4
S10Fan
Old Heap Driver
I've used single stage automotive paint on engines in the past. Get everything clean and spray as you would on body panels.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-05-2013, 11:20 AM   #5
rs74
rs74's Avatar
I have been looking at the red scripted black valve covers and air cleaner to go with but I am also eyeing this stuff.
Roy
1987 R10 shortie
Old 04-05-2013, 11:21 AM   #6
rs74
rs74's Avatar
I have seen a few do this but does it hold up to the heat. If so then maybe I could have the engine painted the same color as the lower part of the truck. Hmm. I think the light bulb just went off. Good idea. I will look into it.
Roy
1987 R10 shortie
Old 04-05-2013, 12:49 PM   #7
BigMike608
BigMike608's Avatar
That's exactly how I plan to do my LS
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 04-05-2013, 01:02 PM   #8
Pop's C-10
Pop's C-10's Avatar
i'd go with air cleaner that matched tha valve covers. that one being cf patterned would stand out to much..silver block & heads..black valve covers & air cleaner..black acc. brackets..call it done.
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 04-05-2013, 01:54 PM   #9
dieseldawg142
dieseldawg142's Avatar
have you looked at por15 Engine Enamel paint? tuff as nails,stuff is just as good as por15 paint. did my bb chev 4 yrs ago, NO burning, flaking, rock chips, when dirty, little soap & water & it looks like new
lots of colors (crappy pic)
Size:  58.1 KB Name:  077.jpg
dieseldawg142 is offline   Reply With Quote
Old 04-05-2013, 03:52 PM   #10
Pyrotechnic
Pyrotechnic's Avatar
I like the Pontiac metallic blue as an alternative to Chevy orange.
Dupli-Color DE1616 Ceramic Pontiac Blue Metallic... Dupli-Color DE1616 Ceramic Pontiac Blue Metallic...
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 04-05-2013, 04:05 PM   #11
88Jimmy4x4
88Jimmy4x4's Avatar
Paint everything separate, looks cheesy when bolts are painted over
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 04-05-2013, 04:24 PM   #12
rs74
rs74's Avatar
There is not one. Atleast not with that same company. Proform. I will have to look into others to find a match.
Roy
1987 R10 shortie
Old 04-05-2013, 04:26 PM   #13
rs74
rs74's Avatar
[QUOTE=dieseldawg142;5992931]have you looked at por15 Engine Enamel paint? tuff as nails,stuff is just as good as por15 paint. did my bb chev 4 yrs ago, NO burning, flaking, rock chips, when dirty, little soap & water & it looks like new
No I haven't. Didn't know they made it for engines. Just wanting something other than your typical rattle can spray. I don't think it last very long before fading, chipping, etc..
Roy
1987 R10 shortie
Old 04-05-2013, 06:21 PM   #14
Skunksmash
Skunksmash's Avatar
I'm going with gold! Like oldsmobile.
Skunksmash is offline   Reply With Quote
Old 04-06-2013, 12:35 AM   #15
Paul83
Paul83's Avatar
My truck will be painted close to the same color blue as yours. I will be going with a yellow engine block. I will check into that por15 myself.
Paul83 is offline   Reply With Quote
Old 04-06-2013, 05:54 AM   #16
S10Fan
Old Heap Driver
The motor must be clean, then clean it again. Some folks use base/clear, I prefer single stage, it's easier to touch up when necessary.
Bryan
Old 04-06-2013, 08:36 AM   #17
rs74
rs74's Avatar
The one question I have is regardless of whether it is por or a single stage paint. Does the paint hold up under the heat good with no peeling fading or anything. I know Dieseldawg remarked on the POR but would like to hear from others about how theirs held up.
Roy
1987 R10 shortie
Old 04-06-2013, 09:15 AM   #18
S10Fan
Old Heap Driver
I've painted 4 motors with no issues at all on the last 3. The 1st one gave me problems because I didn't have the surface clean enough. I don't care what kind of paint you use, if you paint over oily dirty surfaces the paint will fall off faster than a hookers pants.
Bryan
Old 04-06-2013, 12:56 PM   #19
dieseldawg142
so true!! prep & cleanliness IS THE ticket to a good job!
without trying to sound like a por salesman, try it, some of their paints are rated to 1500 degrees, my headers are por20, this stuff WILL NOT burn off or brown out. as for durability- paint something with it & smack it with a hammer. i've used their products & seen with my own eye's, if it was crap, it would'nt be on my crew
Old 04-07-2013, 08:24 AM   #20
S10Fan
Old Heap Driver
I'm going to check out the POR engine paint, thanks.
Bryan
Old 04-07-2013, 08:57 AM   #21
durty harry
durty harry's Avatar
VHT Titanium blue
Scott
82 step side aka " Bouncy "
73 GMC
Long bed Vortec 5.7
durty harry is offline   Reply With Quote
Old 04-07-2013, 09:04 AM   #22
rs74
rs74's Avatar
Originally Posted by durty harry View Post
VHT Titanium blue
I have seen this photo before and had said to myself that I liked the color. I do have a fresh 4 over 350 that is painted Olds blue. What did you do, paint the engine and just put the summit sticker on it? I would figure it would have gotten hot and melted or something.
Roy
1987 R10 shortie
Old 04-07-2013, 09:17 AM   #23
durty harry
no stickers , installed a set of summit vortec heads painted the summit stamp dark blue
Scott
73 GMC
Long bed Vortec 5.7
Old 04-08-2013, 02:11 AM   #24
Gryndar
Here's my in progress 355 build.
Gryndar is offline   Reply With Quote
