Mud and Brakes
Wasn't sure where to post this:
I've just finished painting my frame and moving to the rear axle. I have about 2" of caked mud/dirt all over the backing plate. I have the axle cleaned and sanded but not sure how to get this caked mud off. Any ideas? Also curious, I am on a tight budget... is it necessary to replace my drums when rebuilding the brakes? the truck is a 1967 and its been sitting for about 10+ years. Is there anything else I need to do to the rear axle before calling it done? |
![]() Join Date: May 2011
Re: Mud and Brakes
drums can be turned and if you rebuild them you should at the least have them turned.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
Square
Re: Mud and Brakes
oven cleaner will work, but its also gonna remove paint.
Squarebody Syndicate |
Re: Mud and Brakes
I've tried oven cleaner and a high pressure hose. it worked pretty well but i still needed to go over everything with an angle grinder. The backing plates aren't the easiest to get to with one.
