![]() Join Date: Mar 2002
Master Cyl to Proportion Valve Tubing
I have a 68 3/4 ton 4x4 that now has a disk brake front end. I am using a 72 master cylinder, proportion valve and brake booster. My question is how should the tubes from the master cylinder to the proportion valve be connected. I have attached two different photos showing the difference.
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
![]() Join Date: Dec 2012
Re: Master Cyl to Proportion Valve Tubing
I just got through with my 3/4 disc conversion and installed the M/C and proportioning valve. According to the instructions I received, it should look like this. Keep in mind this isn't stock and is a disc conversion on a 70.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
member #16
![]() Join Date: Dec 1999
Top pic looks correct for a 3/4 ton, for some reason they were opposite on 1/2 tons. front to front and rear to rear on halfs.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Cluster King
![]() Join Date: Nov 2012
Here is mine for a 1972 Cheyenne 1/2 ton 2wd.
Here's my '71 K20
71 K20 64 GMC mud truck |
71K20chevy your setup looks original. Is that the case?
I had ordered new stainless tubes from Inline Tube and they look like yours. I had not seen that configuration before.
Yes they are.
