Old 04-06-2013, 01:02 AM   #1
dazza
dazza's Avatar
spring eye bolt question
Replacing the leaf bushings and after taking out my aggressions via grinder, torch, and hammer, of course, there's not much left of the spring eye bolt.
I happen to have the correct size bolts in stainless, however they are coarse thread and not fine like what was there. I know the fine threads would probably hold better although with the stainless I'll be using a nylock nut and (maybe?) a lock washer.
any input?
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 04-06-2013, 02:25 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: spring eye bolt question
Are they long enough to double-nut the bolt, also
Frank
piecesparts is offline   Reply With Quote
Old 04-06-2013, 02:33 AM   #3
dazza
dazza's Avatar
The ones that were on there had a spacer (about 1/4") with the nut, if I exclude that spacer, then two might fit but i'll have to give it a shot and see.
