04-06-2013, 03:23 AM | #1 |
Rear end identification
3/4 ton gmc coil rearend 10 bolt what it is? And pros and cons? Thanks
72 GMC super custom. |
04-06-2013, 03:24 AM | #2 |
Re: Rear end identification
Posted via Mobile Device Here is right side up lol Posted via Mobile Device
04-06-2013, 03:26 AM | #3 |
Posted via Mobile Device Posted via Mobile Device
04-06-2013, 03:30 AM | #4 |
Atleast the person who counted for me saw 10. I'm not to
Sure Posted via Mobile Device
04-06-2013, 03:32 AM | #5 |
I believe that's an HO52 Scott - but would wait for someone else to verify. I'm more a Dana 60 guy in the 3/4 tonners. It's not a Dana.
04-06-2013, 03:32 AM | #6 |
Looks like the ho52 I have in mine
04-06-2013, 03:42 AM | #7 |
I have heard some bad things about the ho52. True? Mine seemed ok on the highway so must have some decent gears in it
04-06-2013, 03:45 AM | #8 |
04-06-2013, 08:40 AM | #9 |
The Eaton axles have a good reputation for strength. Drawbacks are some of the bearings are REALLY expensive if you have to rebuild and the availabiltiy of replacement gearsets is almost non-existent. At one time there was an aftermarket run of 3.90 but 4.10 are the lowest common ratio while 4.57 are probably most common.
