Old 04-06-2013, 10:32 AM   #1
70blackfish
Short or long water pump for 350
do our trucks use the short or long Water pump,
mine is a 69 with a 350 gong in...
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 04-06-2013, 10:59 AM   #2
Sammy
Re: Short or long water pump for 350
Makes no difference which one as long as brackets, n all pulleys are for long or short pump.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-06-2013, 11:01 AM   #3
HotRod C/10
HotRod C/10's Avatar
I am running a long water pump.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 04-06-2013, 11:30 AM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
All small block Chevy engines in pick ups, up to 1972 came from the factory with short style water pumps. The alternator would be mounted on the drivers side. If equipped with A/C the compressor would be mounted on the passenger side. 1973 and later 350 engines came from the factory with long style water pumps and the alternators were mounted on the passenger side with the A/C compressor on the driver side.
My 72 has a 1978 engine that has all of the long water pump accessory's and it works just fine. However, I am going to change it all back to short style because it was original that way and I like the short style better.
TBONE1964 is offline   Reply With Quote
Old 04-06-2013, 11:32 AM   #5
70blackfish
Thumbs up Re: Short or long water pump for 350
Thank you!!
