Old 04-06-2013, 08:12 PM   #1
LynnJr
One More Front Hub Installation ? 1974 4x4
Okay I decided to put my warn hubs on today and the axles don't stick out enough to put the snap-ring into the correct location on the axle.The splined section slips right on but it bottoms out before the recess on the axle makes it out.
I didn't have the front end in the air could that be the cause of the problem?
LynnJr is offline   Reply With Quote
Old 04-06-2013, 10:20 PM   #2
Daveyboy1983
Re: One More Front Hub Installation ? 1974 4x4
Put the hub all the way on the splined shaft and take a pair of pliers or channel locks and grab the end of the shaft and pull towards you a little the axle has a little end play in it put your snap ring on....done
Daveyboy1983 is offline   Reply With Quote
Old 04-06-2013, 11:08 PM   #3
LynnJr
I will give it a try.
Old 04-07-2013, 10:08 AM   #4
LONGHAIR
You can also reach around the knuckle and push the axle into the back of the spindle by hand.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-07-2013, 11:50 AM   #5
LynnJr
Thanks for that suggestion.I never gave it a thought you could get there from the knuckle but it makes perfect sense.
I remember swapping the old red Warn hubs out a long time ago and they just slipped right in.I guess I got lucky back then.
