Old 04-06-2013, 08:32 PM   #1
arturo7
arturo7's Avatar
Steering Column Question
I'm preparing to clean the steering column on my '59. Do I need to seal off the slot near the bottom before I attack the grime with degreaser and a pressure washer?
thanks
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 04-07-2013, 01:45 PM   #2
arturo7
arturo7's Avatar
Re: Steering Column Question
Maybe I should rephrase the question...
Is it OK if water and degreaser get in that hole?
ever forward
Old 04-07-2013, 01:53 PM   #3
OrrieG
OrrieG's Avatar
I would think not. Gently clean around it, duct tape it up and start cleaning, same with the top, you don't want to get water down in the column. I wouldn't use a pressure washer, just some engine cleaner if its really greasy, then Simple Green or similar and a stiff brush. If necessary you could use a wire wheel on a drill or die grinder for rust or really stubborn stuff. Same with blasting, don't want to get sand or ?? down in bearing or moving parts.
OrrieG is offline   Reply With Quote
Old 04-07-2013, 02:50 PM   #4
arturo7
arturo7's Avatar
Thanks, O
ever forward
Old 04-07-2013, 07:47 PM   #5
yossarian19
Yeah, water / grease / junk in the bottom steering bearing are going to kill it. Either knock it out (if its easy enough) or careful not to get stuff in there.
yossarian19 is offline   Reply With Quote
