![]() Join Date: Jan 2002
long box to short box -frame ?
i just got a 6 foot wide box for my crew -cab ,does anybody have any pics and dimensions -so i may shorten my long frame ? also are the 66 1/2 ton leaf springs the same length as 3/4 ton leafs ? thanks {im using leaf springs -and making the truck a 3/4 tonner}
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: long box to short box -frame ?
You need to take 12" out of the frame under the cab, and 8" off of the end of the frame. I believe there is a link in the '60-'66 FAQ Index, to a thread on shortening the frame. I should have pics on one of my computers of one of the ones I have done. It takes some time, equipment and the skills to do it right. Shortening a frame isn't something that should be attempted by a beginner welder/fabricator.
Senior Enthusiast
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
remember that it is a crewcab and may not have proper long box dimensions to start with. I think that it may be prudent to take measures from back of cab to centre of axle on both a stock longbed and a shortbed and compare them to your c/c to see if there are any variances between them and go from there. you want the tires to center in the wheel wells the way that they were meant to be. if they don't look right one can spot it a mile away
ron |
60-66 Nut
I tried to reply to your PM wahl4m, but yout inbox is full. Here are some pics of one of the ones I have done.
#6 | |
Ditto on the Captain's method, ideas, write-up, & pics. sam Last edited by luvbowties; 04-12-2013 at 10:56 AM. Reason: added ditto for Cap's post |
| Bookmarks |
