04-06-2013, 11:35 PM | #1 |
87 with tbi very high idle.
bought an 87 with tbi runs at a very high idle sometimes . when its warmed up is when i notice its when it does it and check engine light is on also.
04-07-2013, 12:44 AM | #2 |
Re: 87 with tbi very high idle.
First off, pull the codes and let us know what they are.
04-07-2013, 12:48 AM | #3 |
TNT-MOTORSPORTS
check the gasket between the throttle body and the manifold , clean the Idle air control valve up. Sounds like a vaccumn leak ... usually is on a throttle body
04-07-2013, 07:51 AM | #4 |
thanks i will try those first . i was thinking the control valve too.
04-07-2013, 11:46 AM | #5 |
buffle
My 87 was as simple as a new radiator cap. The old one was bad and sensor wouldn`t let it idle down.
Life is like a roll of toilet paper. The older it is, the faster it is used up. |
04-07-2013, 04:04 PM | #6 |
ttt for ya
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
04-08-2013, 08:50 PM | #7 |
Lowburb,
Did you find your solution? did you pull the codes? Chris |
