Old 04-07-2013, 10:53 AM   #1
Damon23
Damon23's Avatar
rear shackle install
No where does it cover in the instructions nor in any searchs on how to install the rear shackles. What I mean is their a front and back on the shackle. I have one side that has a back to it and one side that does not. Does the open end face the front or back, or does it matter?
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
Old 04-07-2013, 08:13 PM   #2
Mike C
Mike C's Avatar
Re: rear shackle install
The open side needs to face forward on the truck. As the spring flattens out and the shackle extends towards the rear of the truck, the open area allows for additional clearance of the spring.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-07-2013, 09:46 PM   #3
tinydb84
tinydb84's Avatar
You will also need to cut the bed support.
David
Instagram: myfabguy
Old 04-08-2013, 04:47 PM   #4
Mike C
Mike C's Avatar
You might. I did not cut the bed support on my 70 GMC 3/4 ton long bed, but on a 1/2 ton your mileage may vary.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 04-11-2013, 08:10 AM   #5
sKnNyPpY
sKnNyPpY's Avatar
Are these on backwards? This is on a 71 longbed 2-1/4 leaf and I ride REAL low after a DJM flip. Another board member thought these were drop shackles but I got the same size as these when I ordered 'stock' shackles. There is also a debate as to whether my 3-1 leafs had some removed from 5-1 or if it came that way, I only see 5-1 as replacements. Thanks.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 04-11-2013, 10:12 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Mike is correct. It will depend on the wheel base, and the spring length. On 73-87 trucks you had two different leaf spring lengths as well as wheel base lengths that determined if the bed brace would clear or not.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-11-2013, 10:15 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
That appears to be a stock shackle. Most aftermarket (not all) will have extra holes so you can drop 1" or 2".
I am inclined to agree that you might have leaves removed from your spring pack. I don't know specifically how many configurations were available on 67-72's with leaves, but that looks really low for w flip kit with a stock shackle.
Articles-
"Refining Sierra"
Old 08-24-2017, 11:21 PM   #8
PaPaStewySnipes
I'm in the same boat, I am unsure if some were removed. Pic of mine below, I am afraid if I do a flip I will be less than an inch from frame. Any info. On looking for a 4-6 drop in the rear, depends on what is possible then I will drop front accordingly to level the truck out.
PaPaStewySnipes is offline   Reply With Quote
