Old 04-07-2013, 04:05 PM   #1
pontiac6269
pontiac6269's Avatar
Corporate 14 bolt FF ?
Is there a way to identify what the gear ratio is without removing the cover or turning the wheel and counting wheel and driveshaft turns (no driveshafts)? This is a rolling frame. Any codes on the axle tubes or center section? Local yard has this and said $100 for the rear or $300 for every thing (rear end, leaf springs, front end, leaf springs steering linkage, steering box and pump and all brackets mounted to the frame). He just wants the stripped frame back.(frame is bent). This is a 3/4 ton regular cab long box, not sure if a 73-80 or 81-87. Will take a look at it again Monday to see what the front frame horns look like and will take a camera.
Thanks,
Eric
Eric
2001 Ford F350 EC dually 7.3
1981 Chevy C20 to K20 350
1978 Oldsmobile Cutlass Supreme 455 Pontiac
1969 Pontiac GTO 400
pontiac6269 is offline   Reply With Quote
Old 04-07-2013, 05:41 PM   #2
obijuan
Re: Corporate 14 bolt FF ?
If untouched the front diff cover should have a tag if its a Dana 44. Otherwise just pop the cover and see. Might have a Detroit locker!.
obijuan is offline   Reply With Quote
Old 04-07-2013, 06:17 PM   #3
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
There may be a tag on the front, but I would pull the covers to see how they look inside before buying. Just to make sure the bearings aren't trashed inside and the oil isn't full of metal chunks. All it takes is a drain pan and a couple wrenches to pop off the covers.
300 bones for axles, springs, steering, etc you can't really go wrong.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 04-07-2013, 07:09 PM   #4
LONGHAIR
The front axle itself will give you a clue as to it's year. If it's a Dana 44, that puts it before '78, after that would be a 10 bolt corp. axle.
As far as internal parts, it could be anything. If there is anything in there other than an open carrier or a Gov-lock, it's aftermarket. After all of these years, it could be anything though.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-07-2013, 07:16 PM   #5
in deep 72
in deep 72's Avatar
Everything you ever wanted to know about the 14bolt FF.
http://www.pirate4x4.com/tech/billavista/14b_bible/
in deep 72 is offline   Reply With Quote
Old 04-08-2013, 02:41 PM   #6
pontiac6269
Pulled the rear cover, didn't pull the front as it started raining. Front had a tag that said 45 11 4.09. So it looks like the it has 4.10 gears. The frame is a 73-80. Rear looks real clean inside. What front axle is this 10 bolt? Have pictures below.
Thanks,
Eric
Eric
Old 04-08-2013, 02:54 PM   #7
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Originally Posted by pontiac6269 View Post
the frame is a 73-80. Rear looks real clean inside. What front axle is this 10 bolt? Have pictures below.
Thanks,
eric
d44.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 04-08-2013, 04:00 PM   #8
Redcap
Thanks,
Eric
Click me!
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 04-09-2013, 04:44 PM   #9
obijuan
looks like it says 41 11 and its a gov lock if you were wondering.
Old 04-10-2013, 08:45 PM   #10
pontiac6269
I wasn't sure about how to read the gear ratio on this because the first number is a 10 but then it's stamped 41 11 after. So this makes the rear gears 3.73? According to the tag on the front differential cover the front is 4.09. It started to rain so I didn't pull the front cover to check the gears and we've been getting rain since then. One of them must of been change at one time maybe. I did give them some money down to hold it for me.
Thanks,
Eric
Eric
Old 04-10-2013, 09:00 PM   #11
obijuan
I zoomed in on my phone and 11 79 is the date and 41 10 is the ratio.
