Old 04-07-2013, 11:09 PM   #1
damianbryand
First time drive
Well I drove my truck for the first time today. After 2 months of this and that tinkering I drove it around the block twice. I noticed the tranny wouldn't shift gears. It felt like it stayed in first the entire drive. Any ideas what it could be? It's a turbo 400. Thanks!
damianbryand is offline   Reply With Quote
Old 04-07-2013, 11:50 PM   #2
SS Tim
SS Tim's Avatar
Re: First time drive
Well from what I read you have a 68 C10, stuck a used motor in front of an unknown trans. Did you ever get the fluid and filter changed? What did the fluid look like? Is the fluid level correct hot? How fast were you driving the truck (no throttle 1-2 upshift is like 5mph and WOT is about 25-30mph)? Is the vacuum modulator hooked up? Did you download the service manuals?
SS Tim is offline   Reply With Quote
Old 04-07-2013, 11:52 PM   #3
o6r1man
o6r1man's Avatar
You can also try and shift it manually and see if it shifts....
1970 SWB "old flame"
1967 SWB c10 sold
1972 Elcamino 496
2012 Denali HD dmax
o6r1man is offline   Reply With Quote
Old 04-08-2013, 08:40 AM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Check your vacume lines from the back of the manifold to the modulator, you could have some cracks/leaks.
Tom Vogel is offline   Reply With Quote
Old 04-08-2013, 09:13 PM   #5
68streetrod
x2 with out vacume it will not shift on a TB400
68streetrod is offline   Reply With Quote
Old 04-08-2013, 10:42 PM   #6
JointTech
JointTech's Avatar
i dont see how you got around the block 2 times in 1rst?? mine shifts out at 5mph and sounds like its going to blow if i hold it in first.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 04-09-2013, 12:22 AM   #7
buckskins4ever
buckskins4ever's Avatar
Agreed...if you hadnt rechecked your vacuum lines, try starting there first. You really should put the trans and power brake booster on dedicated vacuum ports. everything else can share.
buckskins4ever is offline   Reply With Quote
