Painted my dash bezel and cab corner moldings this weekend
Getting all the little stuff ready while my truck is getting painted.
Spent most of this weekend masking, painting, then masking, then painting. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Re: Painted my dash bezel and cab corner moldings this weekend
good job. sweet looking corner trim peices
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373 1984 Chevy C10 short bed 2001 Chevy Impala police cruiser 2001 Chevy Silverado 1500 Z71 4wd extended cab ![]() |
![]() Join Date: Dec 2012
Those came out great. They look new. Good job.
![]() Join Date: Oct 2011
perfect color choice on those corners......looks great
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
sweet, love the cab corners!
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop |
78K & 79C Jimmys
nice work on the bezel
is it just repainted or did you do something to raise the texture
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Just repainted the dash bezel. In the second picture, it looks flat because I scruffed it up with a scotch brite pad. The third picture was after it was painted with SEM paint. Now I have to scruff up the black around the gauges again to apply my brushed aluminum applique.
That looks good. Must have taken a long time to mask those pieces.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
I know the pieces fit
x2
The bezel looks good too but those cab corners are great. |
78K & 79C Jimmys
it looks really good
I want to fix mine ,and had thought of bedliner spray, for texure
wow, nice job, love the corners.
Jeff Shaw 2003 Chevy 2500HD LB7 Duramax ![]() |
#13 |
How did you clean up the silver over spray?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#14 |
That looks great. How do you remove the cab corners? I am afraid of tearing mine up.
#15 |
Home Built '87
Very nicely done!!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
#16 |
I sprayed the silver first since it was the toughest to mask off. Then I masked off the silver and sprayed the black, which cleaned up most of the silver overspray. Then I got a really fine brush and touched up any spots that were over or under-masked.
#17 |
The cab corners have a 10mm nut that holds them in place. You have to reach underneath the opening from the inside of your cab corner to get to it. Once you take the nut off, just wiggle them slowly and they'll come apart and slowly slide apart from the rear cab molding. You have to use a little bit of care not to bend or twist them.
#18 | |
