Finally dropped in the motor!!
Its been a really busy semester but finally got to drop in the motor this weekend. Here are some pics of my progress so far. hopefully will be my daily driver sometime this summer.
Re: Finally dropped in the motor!!
Looking good!! what CI is that? Anything done to it, or is it stock?
Don't forget that bolt at the bottom of your motor stands!!? Looks good though.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Its a stock 78 gmc c35 350 engine going in my 69 c10. just disassembled it and put new gaskets. pistons checked out good.well i was gna try it like that with just the 3 bolts on the brackets. 2 on the frame and the bottom one at the crossmember. If not just drill the hole to bolt all 4.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
bolt all 4, you'll be peeved if it twists
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
