Old 04-08-2013, 01:31 PM   #1
WhippinSaw
WhippinSaw's Avatar
door striker spacer?
My 1963 driver door striker has these two spacers behind it but my passenger door does not. Do I need them? Does anyone else have these in their truck? I ordered new strikers from classic parts but they didn't come with the shims. I think they are there so you can adjust the striker w/o damaging the paint.
WhippinSaw is offline   Reply With Quote
Old 04-08-2013, 01:35 PM   #2
1963c-10
1963c-10's Avatar
Re: door striker spacer?
They are in both of my trucks. 63 & 61
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-08-2013, 02:21 PM   #3
PAPA KENT
PAPA KENT's Avatar
i think i might have some spares if you need them.
PAPA KENT is offline   Reply With Quote
Old 04-08-2013, 02:33 PM   #4
losthope
losthope's Avatar
I just sold a set of strikers and the shims on ebay that i took off a 63 both doors had them, and a 63 panel I helped a buddy tear down had them on both doors also...I dont think they are really there to protect the paint but more for fritcion and adjustment of the striker and keep the striker from moving around.see all those little lines cut into both sides of the shims those are for gripping on to the pillar and on to the striker without those the striker would be able to slide around on the pillar even when bolted on tight....
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 04-08-2013, 03:00 PM   #5
WhippinSaw
WhippinSaw's Avatar
Thanks Papa Kent. Take a look, I Would buy them if you don't need them.
Kinda thought they were there for a purpose
Thanks for the post 1963c-10, guess I will have to find some.
Old 04-08-2013, 03:12 PM   #6
1963c-10
1963c-10's Avatar
I have an extra if you need one. PM me an address
