Old 04-08-2013, 01:51 PM   #1
jorgensensc
jorgensensc's Avatar
Radiator overflow question.
So I'm going to use the radiator from the donor vehicle (08 escalade 6.2) in my 72 burb. There is no cap on the radiator like my old radiator. Do I need to run the overflow unit from the donor vehicle? Does it have a special pressurized cap on it? Can I use any overflow container with a lid, or does it have to withstand great pressure?
Are these new cooling systems not pressurized?
Thanks in advance!!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-08-2013, 08:54 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Radiator overflow question.
The overflow tank from a 99-up is needed if using the donor radiator.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 04-08-2013, 08:57 PM   #3
jorgensensc
Ok. Thank you for the reply!
Old 04-09-2013, 10:36 PM   #4
themb2g
Reccomendations on an overflow tank to buy?
Check out my build: 1972 LQ4 Swap
http://67-72chevytrucks.com/vboard/s...=1#post5427693
themb2g is offline   Reply With Quote
