MOTORHEAD!
Aluminum inner fenders?
Anybody here know anyone that custom makes them for
73-87's? I have seen the fibreglass ones but prefer the aluminum... Posted via Mobile Device
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi/3.42 Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Ryan Brown Performance 850 Holley Full weight long box pickup Current best- 11.28@119mph |
Re: Aluminum inner fenders?
For bagged drops or aluminum oem style?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
MOTORHEAD!
Just something to lighten the front end for drag racing.
Most just take them out. But it may be possible (small slim chance)
That you can make a call to gm goodmark repop and have them press aluminum instead of steal. I wanted to do this with the front fenders an inners myself along with the bumpers. Kinda like the old z33 rpo that never happened. All the front was aluminum. Meanwhile a fiberglass hood will net a greater margin of weight loss Plus moving things back help so a blazer tank instead of saddle tanks and rear mount battery help hooking up. Posted via Mobile Device
MOTORHEAD!
What is the weight of a factory hood? 80 Lbs?
A few questions and we may can come up with a recipe for you.
1. What is the weight of your truck with you in the seat and a half tank of gas? 2. How much HP does your engine make? 3. What tires are you running out back? 4. How fast do you want to go? (I know this one is tricky!, we are never fast enough)
V.P. of The American Squarebody Association. 1982 Sierra, 555 BBC, All Billet 700R4, Fab9 with 4.11's, Full 8.5 cert cage, 31x18x20 MT Sportsman S/R's on custom made 20x15 Amer. Racing Hopsters, 4-link with anti-roll bar and dual adj coilovers, Front drag shocks, Custom interior, and quite a bit more. |
MOTORHEAD!
Roughly 4150, 707hp, 30x12's, low 11's.
With those numbers you should already be at that time. Have you had your engine dynoed?
you can get deep into the 11's and possibly into the 10's with that HP and weight, but a gear swap may be needed to get you there. Are you having any issues putting the power to the ground, or do you have any traction helpers?
Need much better gears than 3:42
What's your trap speed rpm and mph? What else have you done to it? Posted via Mobile Device
MOTORHEAD!
Engine was dynod when built, I am nearing completion of the reassembly of the whole drivetrain... Hope to fire it by the end of next week. I have the 3.42's as I plan to use this 80% on the street. I will run 30x10 radial slicks @ the track, and I am running Caltracs on the leafs. Once I get the rear lowered I can measure for my adj. shocks, driveshaft, etc...
3:42s are going to kill you at the track. When you lower it get the front spring eye as high as you can and get the instant center working for you. I would suggest a built 2004r overdrive trans and 3:91s which will Prob get you to your goal and still be more street freindly than your current setup. But I'm certain you Prob have the th400 built real well.
Tonneu cover helps too. Posted via Mobile Device
MOTORHEAD!
I fail to see how the 3.42's kill me? At 700 ft lbs does the gear really make that big of a difference? It's a TCI Super Street Fighter with an ATI 3200 stall.
#13 |
If you are looking for better track times, gears are a major factor. Big blocks need less gear, but I would recommend a 3.90 or similar to give you the best of both worlds
#14 |
How much boost was those HP numbers on?
#15 |
MOTORHEAD!
zero boost.
#16 |
I mean no offense whatsoever here, but I don't trust those hp numbers. Not saying they are wrong, but it is very unlikely for a 496 to put those numbers down. Not impossible, just unlikely on pump gas. But that is neither here nor there. Gears will really help you out a lot
#17 |
MOTORHEAD!
Proof is in time slips, and my builder's engines are in all of the fastest BB steel headed Chevelles in the USA. If I told you my cam specs you'd doubt it even more!
#18 |
MOTORHEAD!
We are waaaaay off track here though! I see the glass hoods weigh about 40 lbs for the ones that are not just pinned down... What does the factory hood weigh? I saw on Goodmark that it's 124 lbs? SERIOUSLY??!!! I sent them an email regarding an aluminum re-pop... We'll see if they reply!
#19 |
Lol. Wasn't saying it was wrong. I know that sounded bad tho. What times have you ran so far?
#20 |
MOTORHEAD!
As mentioned just finishing assembly in the next few weeks here. I don't expect to be blasting low 11's right off the bat or anything. I am going to need to re-learn to drive it before I can go hard on it... Going to be quite a difference compared to the 340hp 383 it replaced! And I know you meant no harm! I just hope everything goes together smoothly so I can get the darn thing on the road!
P.s. Your truck is F'n AWESOME. Love the rear meats!
#21 | |
Maybe you should look at gear vendors overdrive and new 3:91 gears Are you using a truck 12bolt as well? Posted via Mobile Device
#22 |
MOTORHEAD!
Yes truck 12 bolt. 3.42's, Eliminated c clips, big bearings @ axles, Ferd drums, Mark Williams axles etc.
Here is a 657hp steel headed version of my engine. Mine has aluminum heads, and 50 more hp. I realize this guy is in an arrow and I'm in a brick! His gears were 3.08 at the time of this video. He has since switched to 3.31's and has a best of 10.59.
#23 |
MOTORHEAD!
The 12 bolt
#24 |
Truck 12 bolts have a small pinion shaft diameter. The truck ten bolt actually has a bigger pinion gear and when built will do 10s reliably. So watch that pinion!
Let me know what you head from gm goodmark. If they short you see if you can get a higher up person on the phone Posted via Mobile Device
#25 |
MOTORHEAD!
Yeah, I asked about it and mentioned possibly a bulk order. Asked about inner and outer fenders. Hopefully it works out!!
| Bookmarks |
