04-08-2013, 03:47 PM | #1 |
Rebuilt motor not firing
Any ideas would be helpful. Rebuilt 350, set it on frame, new plugs,wires,distributor,points etc. I get 12v out of coil wire but nothing out of the plug wires so voltage seems to be getting to the points, not sure where to check now.
04-08-2013, 03:53 PM | #2 |
Re: Rebuilt motor not firing
spark, fire gas is all u need but spark is very important at spark plug
04-08-2013, 03:54 PM | #3 |
do you get spark out of the coil when ground side is connected then disconnected?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
04-08-2013, 04:53 PM | #4 |
have you set the point gap and dwell?
04-08-2013, 05:14 PM | #5 |
First place to check is to make sure the points are opening. If I remember correctly (it's been a long time) the points gap should be about .019 when the top of the lobe is in contact.
That should get you in the ballpark. |
04-08-2013, 09:51 PM | #6 |
I am a Referee of life.
Check the rotor.I've forgotten it and had a day or 2 looking for a problem that I created.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-09-2013, 05:48 AM | #7 | |
Sam |
