04-08-2013, 04:37 PM | #1 |
parts cost for static drop
Was trying to find out the total parts cost to lower a 1969 c10 shortbed
Not sure what the lowest static drop is but thats what id be inquiring about. Thanks guys A buddy offered to bag my truck just seeing the price differential between the two Posted via Mobile Device |
04-08-2013, 06:57 PM | #2 |
Happy to be here
Re: parts cost for static drop
Your going to need to do some research on your won before we can offer accurate advice. How low do you want to go? Do you want the best, the cheapest, or somewhere in between?
I will help you, if you will help me...
04-08-2013, 07:07 PM | #3 |
Hahah if I went static itd be the lowest I can go.dont mind notching the frame
If I bag it id do a setup similar to my chopped 1949 ford 2 compressors one large tank , 3/8 valves Dont need all the fancy digital gauges to read the psi thats in the bags, or any of the other extras. Dont know what is offered.on my 49 there are no kits so we had to have a triangulated 4 link done up after we took some measurents. Posted via Mobile Device |
04-08-2013, 07:16 PM | #4 |
I dont know if I can run it just to only go up/down
I really dont have a need for the side to side stuff, its not a 64' impala lol Just trying to keep it as simple as possible. Not over the top with all the bells and whistles.my 49 is my show car, this is more of a rough around the edges daily driver.I like the look of an all original c10 with patina on airbags . Just need this one to lay frame, and go up /down :-) If I were going the show route id opt for all the bells and whistles.this one im gonna drive for a bit then sell, so im trying to keep the spending to a minimum Posted via Mobile Device |
04-08-2013, 07:24 PM | #5 |
67-72 parts collector,…
Since you didn't say,... I will assume your truck is a coil spring truck, not leaf spring?
Comparing the cost of bags vs static drop is not the same. Bags are just air springs. They will replace the coil springs. The added cost of the air management can't be figured in. But,... both suspensions will need: Drop spindles Disc brake conversion Drop shocks Rear shock relocators Adjustable track bar.
04-08-2013, 08:12 PM | #6 |
Thanks keith, what did 2 wheel drive 1969 c10 chevrolets come with from the factory??
Im new to these trucks. My truck looks to have coil springs, no leafs to be found in the rear. Posted via Mobile Device |
04-08-2013, 08:27 PM | #7 |
Tot Roddin'
I would assume your truck had coil springs on all four corners.
Click on Blank Slate in my signature below and it will cover the complete install of an Early Classic Enterprises static drop kit and disc brake upgrade. If you don't find your answer in there just ask. The cost will depend on the kit you buy. I wouldn't choose anything but ECE. Posted via Mobile Device
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
04-08-2013, 08:40 PM | #8 | |
Leaf springs were optional. Just didn't want to "assume".
04-12-2013, 07:55 AM | #9 |
Depends what u want to spend. Cheap coil spring drop couple hundred $. Spindles and disc brakes notch and shocks and etc etc $1000 or more. Bags will be a couple grand or more with air management and proper install. What do u want to spend? The lower u want to be and still be able to drive, the more it will cost. I just spent like $4000 on my suspension without even factoring in labour costs. It's not cheap to do things properly.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
04-12-2013, 01:55 PM | #10 |
I know we did the front in my shoebox ford in very little time. Im sure on the truck its fairly similar , and the lesser cost of the whole setup.grab these for the front
I found a rear setup that is pretty straight forward from ************* Considering it for the rear. They make good stuff, my shoebox has a 4link by them and its never had one issue Last edited by draggin49; 04-12-2013 at 02:09 PM. |
04-12-2013, 03:36 PM | #11 |
Maybe if you think in reverse? Give us a budget, we can give you suggestions to make it happen? (just a thought .. )
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
04-12-2013, 04:00 PM | #12 | |
Registered Cruiser
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
04-12-2013, 04:17 PM | #13 |
I sent porterbuilt an email as far as what options I have. If I was keeping this truck a long time id go for the nicest/high end route.
This truck im gonna sell in the near future.gonna drive it a little bit once completed than let someone else enjoy it. Since I know im selling it and its not a keeper I dont want to spend $6, 000 on a bag setup Im wondering if the rear I posted an image of would lay frame Posted via Mobile Device |
04-12-2013, 04:24 PM | #14 |
I can get the rear setup I posted a pic of for. $1,299
Seems pretty reasonable Posted via Mobile Device |
04-12-2013, 04:27 PM | #15 |
Next option is the porterbuilt rear at $1, 999
04-12-2013, 05:33 PM | #16 |
Registered Cruiser
That set up will lay out.
04-12-2013, 06:07 PM | #17 |
Thanks JNJ, I just wanted to double check. Removing the original motor this weekend.its only got 48, 000
Miles just has been sitting.gonna clean/repaint engine compartment/firewall.then change some gaskets swap new accessories while its out. As soon as its running well, brakes are ok ill order up that kit and some other needed components for the air ride. Should be quite a change from current height Posted via Mobile Device |
04-12-2013, 06:23 PM | #18 |
I probably went as mid grade as you can go disc swap from doner, 4/6 drop with springs and spindles, drop shocks relocators and delux panhard bar, drop trailing arm member (not needed) . Then i cut the frame between steering box and core support brackets dropped the horns 3 in,relocated cab mounts on frame raised floor 2 in in the center,flipped the bed brackets, gained a 3 " body drop. Front bumper is 5" off floor rear about 8" with tall tires. Now if i did a notch added a block in the rear and installed bags aired out id be close to the dirt. Also where im at now is at the verge of trimming front fenders and aftermarket hood hinges. Its going to be close if i go larger on tires deffinatly!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
04-14-2013, 07:01 PM | #19 |
