motor mount
Does anyone know the size and length of the bolt that goes through the middle of the mount on a 70c10 w/350
"Your trucks fast! You must have been going 120 when I passed you." "Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay" If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties... |
Re: motor mount
Sounds like you are looking for call out number six.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: motor mount
Yes, but don't trust that completely. The aftermarket mounts sometimes use different sized bolts. I've seen them with 3/8, 7/16, and even 12mm. The Chinese like to keep it interesting.
Posted via Mobile Device |
Re: motor mount
Too true... replacement parts are just that, functional replacements.
