Old 04-08-2013, 06:59 PM   #1
McCoyAZ
McCoyAZ's Avatar
What brand of wheel is this?
I know this is an artists conception of this truck but I am wondering who makes a wheel that looks like this?
Anyone have an idea?
Thanks,
Scott
might actually get my truck back on Friday if i'm in town.
McCoyAZ is offline   Reply With Quote
Old 04-08-2013, 07:10 PM   #2
TommyDuncan
Re: What brand of wheel is this?
I don't know of any wheels that look like that with a beauty ring.
Centerline makes an aluminum wheel that would look similar to that if you painted the center.
I don't remember the name of it but it is the same wheel that Delmo modifies to use a stock center cap(he has at least a couple builds on here, Grey Goose and Nacho in the 67-72 build section).
From reading his build threads I'm pretty sure he would point you in the right direction in finding these wheels.
TommyDuncan is offline   Reply With Quote
Old 04-08-2013, 07:14 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Wheel Vintiques, Pete Paulsen, Stockton Wheel, etc. make steel smoothies of many different widths and backspacking for use with center caps and beauty rings.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-11-2013, 12:12 PM   #4
McCoyAZ
McCoyAZ's Avatar
Thank you for the information, it gives me a starting place to look.
If I can ask one more question.......
Any idea what the front bumper is off of or which truck bumper would most closely approximate this one?
thanks again...
Old 04-11-2013, 12:39 PM   #5
vin63
vin63's Avatar
Since it's a rendering, it could be just a case of artistic license...maybe a stock bumper flipped?
Old 04-11-2013, 12:45 PM   #6
McCoyAZ
McCoyAZ's Avatar
It is hard to say what it might be.
One guy sait he thought it was fashioned after a mid 70's front bumper...maybe?
I see that the bolt holes have been welded closed and ground off flat. Nice clean look.
Old 04-11-2013, 12:54 PM   #7
TommyDuncan
The top looks chopped and the rear fenders widened also. To run that big of a back tire you would also need an inner fender well. Someone on here used a cut down one from a fleetside.
Old 04-11-2013, 02:22 PM   #8
aggie91
I'm just glad to be here!
aggie91's Avatar
That's a nice rendering, the bumper looks like a stock one, just smoothed out. The wheels look like steel smoothies with baby mooon caps and rings.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
