Old 06-20-2003, 04:09 PM   #1
Blue68
Blue68's Avatar
Wiring cleanup/safety idea
What do you guys think about this? Maybe it's nothing new but....
I'm thinking of connecting the alternator wire to the starter battery post so so I can clean up that wire instead of running it to the distribution block on the fender. The way it is now leaves the entire electrical system open to the alternator since the fusible link is between the block and the battery, not the fuse box. The fusible link connects from the BAT positive post to the junction block and the 10 ga goes out the the fuse box and other accessories.
Seems cleaner. Any thoughts?
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 06-20-2003, 05:22 PM   #2
crazy4chevs
crazy4chevs's Avatar
isnt that the way that the 73 up chevs are? should work fine.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 06-20-2003, 05:27 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've seen i done, no problems at all. Just make sure to keep the wire from the heat of your manifold/header.
