04-08-2013, 09:10 PM | #1 |
Anyone running a Blazer Gas tank?
Im thinking about running a 79 Blazer gas tank in my 58 apache. Has anyone else put one of these tanks in their truck? Any pics? Thanks in advance..
1958 Chevy Apache Stepside 1955 BBW Fleetside |
04-09-2013, 12:35 AM | #2 |
Re: Anyone running a Blazer Gas tank?
I did for years in my 56, just swapped it out for a more shallow one, did not need the extra gallons like I did when I drove it to work everyday. This was the poly one. I made brackets for the side out of two piece of angle iron welded to the frame.
Retired and too busy to work. |
04-09-2013, 02:34 AM | #3 |
Heres a Mustang tank
and a plastic tank (2 pics) same truck
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
04-09-2013, 08:31 PM | #4 |
im looking at the 25 gal tank. it is like 33" wide so it so fit right into the frame with little mods. so i think i am going to pull the trigger and get one. will post pics when i get it.
04-09-2013, 08:42 PM | #5 |
I found this article where someone used a 1987 Blazer tank on a 1957 truck
http://www.classictrucks.com/tech/11...cab_fuel_tank/ |
04-09-2013, 11:38 PM | #6 |
My old one is sitting in the garage with the sender. Its dirty from use on the outside. Not sure what the shipping would be from Washington, but if you want it we can work out shipping charges only.
04-10-2013, 08:37 PM | #7 |
this is the tank im looking at
04-12-2013, 01:15 AM | #8 |
04-12-2013, 10:04 PM | #9 |
sqrints that looks good. what kind of straps are you going to run
04-12-2013, 11:12 PM | #10 |
I tried to use a 40 gallon suburban tank and ultimately decided against it. You may have more room since your truck is a tf series though. It just hung way too low for me. Here is a thread i started about it that may be of interest to ya:
http://67-72chevytrucks.com/vboard/s...d.php?t=554913 This a a shot of the s10 blazer tank i ended up using. It worked out really well. The tank only cost 60 bucks from rock auto, i also piced up a new pump/ sender and some stock s10 blazer straps. I would buy it again. Posted via Mobile Device
My Lost and Forgotten build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=442712 |
04-13-2013, 12:08 AM | #11 |
04-13-2013, 02:51 AM | #12 |
Awesome progress man..How do you do the White around the Tire's ?
1971 GMC Sierra 1959 GMC 100 |
04-13-2013, 04:44 PM | #13 |
Purdue looks great and Sqrints thanks for the help I think i am going to buy 1 just wanted to see how it would look under the truck. What are you going to do for a filler neck?
04-13-2013, 05:31 PM | #14 |
I cut the stock neck down and used that. My bed floor will be raised due to the step notch, so gas filler will be in the floor.
