Where to buy this part?
Tonight after putting in a new trunion bearing for the shifter on my New Process 435 transmission that came in these trucks from 1968-1972, in shifting out of 1st into neutral, the top casing broke as shown in the picture. Does anyone know where to get one?
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
Re: Where to buy this part?
They put the 435 in Dodge and Ford also. The top cover should be the same. You could contact Novac Industries and they should be able to tell you for sure. The 435 is kind of a rare bird in the GM's. They are a close ratio.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
