engine is rebuilt. trans almost done. I got a question...
So the 350 is all done and ready to go. Gotta run a power wire for electric choke. Transmission is being finished and hopefully done later this week.
Looking at install this weekend... Hopefully. Question though. I installed new heads and a new aluminum intake. I know longer have the engine hooks I will call them on opposite corners of the intake where I hooked the chains from engine hoist/picker. once I bolt the transmission back to the engine where do I now hook up the chains for the engine hoist? The normal hooks don't fit the new intake and heads. Can I use one of the bolt holes on the front and back of the heads or should I install the engine and transmission separately? or bolt into somewhere else?
Thanks, Joe 1972 C10 350 Auto |
Re: engine is rebuilt. trans almost done. I got a question...
Can you not use the back manifold bolt holes on the back two cylinders? I used them to install a whole setup on a chevelle once.
Get a engine lift plate.Here is a link http://www.jegs.com/i/JEGS/555/80044/10002/-1
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=531265 72 Cheyenne Super 90 Z71 S.B. 434 C.I. Stroker 78 Camaro Z28 (gave to wife she is restoring it) |
I always wondered how an engine lift plate would react with an aluminum intake. Are the threads strong enough to support it? Or are they just for cast intakes?
Parts and more parts
I have used the engine lift plate on my truck engine several times with an aluminum intake. You could also use a engine leveler fro Harbor Freight.
http://www.harborfreight.com/3-4-qua...ler-67441.html
Frank |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I use my lift plate on every engine. An iron headed big block an turbo 400 here. That's an Edelbrock aluminum manifold. The lift plates work well.
![]() Posted via Mobile Device |
