04-09-2013, 04:32 AM | #1 |
Another Drum To Disc Conversion question
I have a 68 TRUCK I wanna use a 73-87 drop Spindle. Can I Just Use Upper And Lower Ball Joints from a 73-87 or does the tie rod gotta be changed too?
Thanks for any info Posted via Mobile Device |
04-09-2013, 04:54 AM | #2 |
Re: Another Drum To Disc Conversion question
A lot of good reading here that should clear up everything.
http://67-72chevytrucks.com/vboard/s...68&postcount=4
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-09-2013, 06:13 AM | #3 |
67-72 parts collector,…
Easier to use 63-70 conversion drop spindles.
Same price as 71-72 and 73-87 drop spindles. Posted via Mobile Device
04-09-2013, 09:02 AM | #4 |
You would use the 73-87 tie rod too but would have to get a conversion sleeve that will connect that to the 68 inner tie rod
04-09-2013, 10:40 AM | #5 | |
The conversion tie rod sleeves don't connect to the '68 inner tie rod. Because the 63-70 inner tie rods have the wrong thread pitch. (RH thread) Your new 73-87 outer tie rod is ALSO right hand thread. So you have to intall a '68 outer tie rod in the INNER location,,... to use these sleeves. The other option is to use ALL of the 73-87 steering linkage. Like I said,... the easiest option is to buy 63-70 conversion spindles. No balljoint change or tie rod change. $229 every day.
04-12-2013, 07:24 PM | #6 |
My cpp modular spindles came with 73-87 upper and lower ball joints and also new inner and outer tie rod ends and sleeve adjusters
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
04-12-2013, 08:09 PM | #7 | |
Totally unneccessary to change all of that stuff anymore,...
