Old 04-09-2013, 08:28 AM   #1
mrhurt73
Fan 2 cycles on and off then on then off.
I finally got my LM7 running, just got the ECM flash on sunday. but when the engine heats up to fan 2 on setpoint it cycles on and off constantly.
my engine is a 2000 GMC 5.3L LM7 stock, but not using clutch fans, using dual electric fans run off the ECM.
now from the HP tuner software i can manually run each fan and it does fine.
so i am fairly sure the wiring is ok. it has to be a setting in the ECM.
any help would greatly be appriciated.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 04-09-2013, 11:15 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Fan 2 cycles on and off then on then off.
I would try turning your fan 2 off temp down a bit more than it is.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-09-2013, 11:40 AM   #3
mrhurt73
ok can try that, maybe i also saw something once i posted it.
does the ac disable fan 2 at mph have anything to do with it?
My Projects-
Old 04-09-2013, 02:24 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Well, this may be a weird analogy but home furnaces (blowers) will short cycle (on and off cycles) if the ON and OFF point are too close together; I'd have no reason to thing these wouldn't work the same way.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-03-2013, 10:05 AM   #5
mrhurt73
i changed the AC enable and disable psi to 500
and changed Recirc Option to fan #2
and it fixed it, yeah!!!!!
My Projects-
