72 gmc front cross member to 68 chevy?
I located an 8 lug front cross member that I would like to put in my 68 but I thought I'd double check. In 72 where the gmc and chevy crossmembers the same? They are both 3/4 ton.
![]() USMC SEMPER FI 68 Chevy Longhorn 350/400 factory posi |
![]() Join Date: Mar 2003
Re: 72 gmc front cross member to 68 chevy?
It'll bolt right in
![]() Join Date: Dec 2012
Question, why convert a 72 to something older, why not just buy a 67 Truck ?
Just my .2 cents...Its what I'd do atleast
1971 GMC Sierra 1959 GMC 100 |
Cool, it's a 72 going into a 68. Sorry if that was confusing. I've been wanting disc brakes on my 68 for a couple years now
Oh alright now I understand now
Here Twich this should answer any questions you might have.
http://67-72chevytrucks.com/vboard/s...68&postcount=4
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thanks ss! Bookmarked
![]() Posted via Mobile Device
I converted my 69 1/2 ton by swapping the complete frontmember with one from a 73 model, it indeed bolded right on after I had to drill 2 extra holes.
apart from that it's a 3 hour job if the nuts and bolts come off easily. I removed my headers to get easier acces to the north-south facing bolts
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
Are you using the 68 power steering gearbox? Assuming its got power steering. I'm putting 85 spindles and ball joints on my 68 with the 68 control arms. Using the 68 crossshaft with the adapter tie rod sleeves and 85 outer tie rods and 68 outers in the inner position. Just wondering if your having to change you steering box or pitman arm, idler arm...?
i havent gotten that far in figuring out the steering but im grabbing all the steering linkage from the pump on down so i can have plenty of parts to work with. my 68 has power steering. my brother is doing all the work for me since im nowhere near my truck. i could give you more details when he gets his hands on the parts. i asked him to take plenty of pictures to document it. its possible ill be doing the same thing you are, eagle. i have the link from above and my brother will be following those suggestions to do it.
