04-09-2013, 01:25 PM | #1 |
bagged rear angle
1969 gmc 910 bagged 5 bolt swap ....ok so im about to weld the axle mounts on the 5 bolt rear, it was a leaf axle ...what angle do i want my diff? i know what the norm is but do i want to change it being bagged? oh and i have a two piece drive shaft if that changes things.
04-09-2013, 04:34 PM | #2 |
Re: bagged rear angle
what angle is your engine/transmission and first drive shaft set at?
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
04-13-2013, 05:02 AM | #3 |
^X2 You need to match the engine/trans angle only opposite
04-13-2013, 10:13 AM | #4 |
Just did this ... I put mine back together at the same angle it was with the leaf springs... Works great no issues
Posted via Mobile Device |
