04-09-2013, 03:51 PM | #1 |
Master Cylinder
I have a 1966 C-10 with disc brakes all the way around. I am trying to decide which master cylinder to run. The truck is a 3 speed.
Do you recommend power brakes, or manual? Where should I buy the master cylinder from? Part number? I was leaning towards manual brakes, but now I am thinking about this one: http://www.autocityclassic.com/index...mart&Itemid=66 Recommendations? Thank you. Tom Jenkins |
04-09-2013, 04:15 PM | #2 |
Re: Master Cylinder
I went w/manual disc on mine, got the master from obsolete chevy. Easy people to order from and parts arrive quickly and correct.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-09-2013, 04:19 PM | #3 |
Re: Master Cylinder
I think you can just use any daul master cylinder. Were they are all disc i think you dont need the proption valve but i may be wrong?
1964 |
04-09-2013, 04:24 PM | #4 | |
Re: Master Cylinder
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
04-09-2013, 05:36 PM | #5 |
Re: Master Cylinder
If you go with manual you still need proportioning valve due to weight differential from front to rear. Picture of vette loow profile disc/disc, with booster and proportioning valve.
04-10-2013, 01:10 AM | #6 |
60-66 Nut
Re: Master Cylinder
I would definitely recommend going with power brakes. I would also suggest going a big a diameter booster as you can. Those tiny 8" boosters typically don't add much power assist to your braking. I agree on the Corvette master cylinder. Depending on the booster you get, you will likely want one for a '77-'82 Vette. You will also need either a disc/disc specific fixed proportioning valve, or an adjustable prop valve in the rear circuit. The Wilwood 260-11179 is a nice all in one unit. If you need a bolt on (no holes to drill) booster bracket, let me know.
