Old 04-09-2013, 05:38 PM   #1
jayoldschool
Moderator
Bed bolt dismensions and quantities?
Just spend a half hour searching and looking through the FAQs with no luck. Do we have a thread that details the quantities and sizes needed for bed bolts (all bolts: strips, hold downs, wheelhouses)? Wondering if money can be saved by purchasing locally from some place like TSC instead of ordering online.
jayoldschool is offline   Reply With Quote
Old 04-09-2013, 06:03 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Bed bolt dismensions and quantities?
The original bed strips used a spline type carriage bolt. You most likely are using new strips that will have square holes punched in them.
Old 04-09-2013, 06:07 PM   #3
_Ogre
_Ogre's Avatar
you pay dearly for those bolt kits from the vendors.
i believe the shortbed kits have 68 bolt sets
i bought boxes of 100 ss bolts, nuts and washers from boltdepot.com/ for less than what vendors get for mild steel kits.
i also picked up ss bolts for fenders, steps, sills and misc extras at the same time to save on shipping.
the funky washer for the sill bolts is not available except in the kits.
i used standard bolts and recessed the head under the bedwood.
shop air compressor timer
Old 04-09-2013, 06:13 PM   #4
jayoldschool
Moderator
Thanks, Ogre, that's what I'm wondering about. TSC sells bolts/washers/nuts by the pound, and they go on sale for 30% off, too. Not sure if they have stainless, though.
Mine's a long fleet, so it will need more.
It would be nice to have a list of sizes and quantities for those that want to put their own hardware together. I can just count and measure as I take the bed apart if someone doesn't post first.
Old 04-11-2013, 06:03 PM   #5
kevinc
kevinc's Avatar
Unfortunately the P.O. removed all the bed strips, bolts amd related hardware on my fleetside shortbed. I can get hardware at wholesale prices thru my work. If anyone would have a hardware list, it would be really helpful so i know what to get.
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 04-11-2013, 08:47 PM   #6
jayoldschool
Moderator
While poking around my bed today, I found a perfect 12pt socket that will remove the factory square nuts that hold the bed strips in. Of course, I forgot to note the size. I'll post it tomorrow.
It's driving me insane that I misspelled "dimensions" in the title of this thread.
Old 04-14-2013, 03:14 PM   #7
jayoldschool
Moderator
Update: 13mm 12pt works perfectly on the square nuts that hold the factory bed strips in.
Old 04-15-2013, 12:40 PM   #8
kevinc
kevinc's Avatar
Are the bed bolts 1/4", 3/8" or 1/2". I just might bring several different lengths home to see what would work if I knew what diameter they were supposed to be.
Thanks,
Kevin C
Old 04-15-2013, 02:58 PM   #9
jayoldschool
Moderator
I bit the bullet today and did an order from Mar-K. I can post sizes when I get it.
